2009 Hyundai Accent - Timing belts
I have had same issue with my Hyundai 4 cylinder manual, twice, I was told the timing belt needs to be replaced every 60,000 miles
That is not a problem, that is maintenance just like checking and changing your oil.
Wanda , if you have the owners manual it will have the timing belt replacement listed . It will be a mileage number or time in months . That will be better than what someone says .
Also no one here will know what issue you are referring to so please tell us.
