Why does the radio only get certain stations? I changed the antenna…no help
Certain in what way? Only country music? Only talk radio? AM only, FM only?
Is this a factory radio? Give us something to work with!
The radio gets one out of three public stations. The one I am least likely to choose and a few other random stations, none of which are on my go to list…It is a factory installed standard radio with a CD player
Never thought to try the AM dial…still not inclined to do so
Did you replace just the mast ? or the complete wire and base and mast?
FM doesn’t require much for an antenna, but if the wire is bad or disconnected from the back of the radio, you’ll have very poor reception.
It’s also possible your radio is dying.
