cylinder # 6 misfire
That is a statement.
Hello, can you please tell us a bit more about your vehicle and the misfire?
misfires are usually diagnosed by swapping things between cyl 6 and another cylinder which isn’t currently misfiring. If the misfire follows the thing you swapped, that gives you a big clue what’s wrong. coils and injectors are the gadgets to start swapping. that’d be where I’d start anyway.
…duly noted…
Could be a bad coil pack.
could try swapping that coil with cylinder #7 and see if the miss moves. Might just be a bad coil.
I would call this a “coil pack” (1995 Town Car):
And this a “coil” (2007 Town Car):
You would be correct. The 4.6L went over one-coil-per-cylinder in early 2000’s when P.I. upgrades came through
