Just put a new motor, new cat converter, and new starter, fuel pump, and valve cover on. Car has 119k but the new motor has 82k on it. My engine light came on and I got it check out and it said Intake Camshaft position timing was the cause. Now the lights off. What do I do?
Nothing.
If the Check Engine light shuts off, it means the problem no longer exists.
All you can do is wait and see if the light comes back on with the same code.
