engine light on not allthe time eratic
There’s an intermittent problem with the operation of the vehicle that the computer is detecting.
This best thing to be done at this point is to connect a scanner to the vehicle and see if there are any stored history codes.
+1, it’s scanner time…
Most local auto parts stores will pull the codes for you, look for history as Tester already mentioned as well as pending codes…
But you also might have to buy one and drive around with it waiting for the light to come back on and then read the codes (once safely stopped)…
Welcome to the forum…
