put new starter in car, drive it around block, will not start. turning the key on and then to start position, no start, just clicks. put another starter in went thru same procedure drove around block, killed engine, tried to start it, no start. just clicks
What is the condition of your battery and battery cables?
OK, 2 starters and you have exactly the same problem and the starter is not it.
Exactly why did you replace the starter in the first place?
