hard start rough idle rear 3 sparkplugs wet front 3 sparkplugs dry burnt cant hear fuel pump cycling bad two front dogbone motor mounts 2006 chevy monte carlo ltz 3.9l v6
Sounds like a handful. Did you have a question?
For the wet/dry spark plug symptoms, presumably exhaust bank-related, suggest to ask your shop if a fuel trim test would be a good way to start the diagnostic process. You could post the fuel trim results here if you like more ideas.
