How to tell if my valves are bent by the camshaft turning after replacing timing belt
If It runs you may hear some clatter.The valve guides will be damaged and oil will be burned creating smoking exhaust. These things happen after damage has already been done. It would be best to do a compression test or leak down test before you start it.
cylinder leakdown test
