It is not unusual for a 16 year old car to start needing this kind of attention. As in most modern cars, many of the operating parts are physically covered. In order to trace something like an oil or water leak those covers have to be removed. It’s mindless work but it’s still labor you pay for, and it’s in your interest to make sure you only pay for it once. I’d recommend finding a trustworthy mechanic to look at it and give you an assessment. Whoever you used for the oil pan gasket might be ok, but it’s hard to tell from the history as presented. If the front main seal is involved expect to be advised to replace the timing belt and water pump. Be ready for a bill approaching $1000 (mostly labor) and be thankful it’s not the rear main seal that is leaking.
mdixter
21
Related topics
| '04 Pilot, Time Belt replacement >>> oil pan gasket leak? | 11 | 4193 | January 15, 2013 | |
| 2004 honda odyssey coolant leak | 5 | 6973 | April 11, 2015 | |
| Seal oil pump housing and replacing timing belt for 2k? | 2 | 467 | May 3, 2018 | |
| Oil leak after timing belt/h20 pump change | 7 | 7832 | June 18, 2010 | |
| Timing cover gasket leak Honda Civic 2007 | 8 | 5813 | January 10, 2011 |
