Hi all, I need Ideas, suggestions input. Start out with a bad AFR o2, after replaced it can’t do catalyst monitor readyness for emission check, it has been driven over 2000 miles, front catalyst converter temp in 350f, out 520f, the rear converter temp is 350 for both in and out. Anyone have any ideas? Thanks for your input.
You have a sensor or wiring problem. Re-read the temperature values which you have posted, and you will see why those readings cannot possibly be correct.
Thanks bcohen201 for replied.
Turned out that my Tundra post 02 was bad but not bad enough for OBD turn on the light.
I hope this will help anyone with same problem that i had. Goodday.
