I have a electrical oil pressure gauge that i added to car due to ecb board problem with stock gauge. readout of 4.5 to 75 psi but i have needle bounce at 1400 rpm to 1800 rpm and if i let off accelorator it will show 45-65 depending on heat of car. i have never had lifter noise and run synthetic 5w30 oil every 3k . help, gauge fluctuates from negative to 55 range. sending unit has been changed 3 times and my mechanic says “whats up”
Related topics
| Eratic oil pressure reading | 2 | 569 | November 11, 2009 | |
| High oil pressure | 6 | 735 | November 8, 2007 | |
| Intermittent oil pressure gauge operation on 2003 Trailblazer 4.2 | 35 | 18597 | February 19, 2015 | |
| Oil Pressure Gauge Fluctuating | 33 | 64928 | August 25, 2017 | |
| Oil pump | 3 | 462 | January 24, 2010 |
