What cause your plugs to pump oil
Your plugs pump oil? Where do they pump it to? Need a tad more info…
Thank you for your reply so quickly. when you change out your plugs on the end of the plug is covered in oil and if you put you finger in the head where the plug goes you pull back oil on the tip of your finger.
The valve cover gasket or the spark plug tube seals are leaking. A new valve cover gasket set, available at your friendly local auto parts store, will have the necessary components to stop the leak.
Or you can pay a mechanic to install a new gasket and/or seals.
