2002 Chevrolet 1500 - Brake to floor
the brake pedal goes very close to the floor when i brake. cant rember if it always did this.any idieas
Yes , have an independent brake shop look at this if you do not know how to work on brakes . Of course you could check the brake fluid level but I would bet you need pads and the fluid replaced which should be done every 3 years.
If it’s not obvious, this is dangerous, so get it checked immediately.
