Check Engine Light keeps coming off and on; especially after long idles at stop lights. The Mass Airflow sensor was replaced (11/19/19); Oxygen Sensor replaced (11/11/19); Intake Manifold Gasket and Throttle Body Mount Gasket replaced (9/28/2020). It was fine, but has now come back on and off a couple times since then.
Have the codes read and post back and please post the mileage.
Check for any air leaks in the air intake duct.
If air leaks into the engine after the MAF sensor, it’ll set that code.
