2001 Oldsmobile Silhouette - Gas gauge
Gas gauge quick working
By chance did you mean quit instead of quick?
The fuel sending unit is probably failing, possibly due to deposits on the float mechanism
A sharp mechanic can determine if the problem is the fuel sending unit, wiring or the cluster itself
In other words, don’t go to Jiffy Lube to get this figured out
If it turns out the fuel sending unit is the culprit . . . the most common scenario, in my opinion . . . the best option is clearly to replace it. However, you may have luck using top tier rated fuel. On one of my cars, using top tier rated fuel actually fixed the problem. Sure beats replacing parts
