Do you have to pull the engine to get to the oil pan on a 2001 Ford Mustang GT 4.6?
SOHC Or DOHC 4.6L ? The Infomation I’m Looking At Differentiates.
You should have a service manual, anyhow.
CSA
Jack i up, put jack stands under the front end, and crawl under. Is there anything that would interfere with removing the bolts that hold the pan on or dropping the pan down?
