I have a 2001 Miata. It’s been over 100 degrees daily lately. The AC will blow sort of cold for about 30 minutes and the temp gauge will move towards the H hashmarks. If I turn the AC off, the gauge will slowly drop. I’ve also noticed that the amount of cold air is decreasing as time passes. In fact, the other day, the system was blowing air hotter than the outside temperature after about an hour drive.
The viewing glass has bubbling stuff flowing thru it. The recently flushed radiator is full as is the overflow reservoir.
