I have been through 7 fuel pumps in the last 9 months. I purchased the car 1 1/2 years ago with 95000mi from an elderly lady, pulled the car fax and it had no issues and had been back to the dealer every 3000 for every scheduled maintenance and minor routine maintenance. It is a 2001 SES DOHC 24valve.
9 months ago, the fuel pump died right next to the Ford dealer. It had been randomly quitting on me after I would shut it off for a month or so. Then I would hear it priming and knew it would start. Finally, it just wouldn’t start after an hour of trying. Of course, the next morning it did.
Took it to Ford, and it wouldn’t do it for them, but they thought it sounded like a fuel pump problem. The next 3 pumps they put in wouldn’t register a full tank and would indicate that I was low on gas about 50-60 miles before it should, and when filling it, would only take 12 gallons of gas in the 18 gal tank.
The dealer checked the amount left in the tank and verified that it was an 18 gal tank ( which I already knew) when changing to #4 and finally agreed with me that something was amiss. They thought that maybe # 4 would be better because it came from a different place in a different box. These were all supposed to be genuine motorcraft parts.
The next 4 pumps registered a full tank and I was getting about 300 miles before the check fuel light would come on and would take 15.5-16 gal of gas to fill, which was normal. The problem was that they all died after about 600-700 miles. The dealer said they talked to Ford and they kept telling them the same things to check which they did and were all okay. Things like resistance connections. The last pump #7 failed early in the day and still wouldn’t start the next day, but did start after getting it towed to Ford. The dealer attempted to order #8, but Ford had put a hold on all the pumps they had in stock. So either they weren’t shipping anymore for me or there was a much widespread problem. They installed a Carquest pump this time. This one doesn’t register the right fuel in it either. Not as bad as 1-3, but I am getting about 35-40 miles less than I should before the check fuel light comes on and it is taking about 14 gal to fill.
Any ideas what Ford may be missing when they change these out that I might pass on? They probably wouldn’t listen anyway as it took the first 3 before they actually measured the fuel still in the tank even though I had been telling them it wasn’t right.
If # 8 works, should I just live with it not showing a full tank, at least it is working. Either way I am afraid to drive the car to anywhere but work and even that is kind of nerve wracking.
At least the pump has been under warranty every time to I get a loaner and they fix for free, but I want it fixed right!
Thanks for any input
Bri
