2001 Dodge Ram 1500 - One bad tire
Passenger side front tire hops/vibrates when reaching 50-52mph.
Probably out of balance, or bent wheel, take it to a tire shop to have it checked out…
Make sure wheel bearing or other steering and suspension parts are not loose and or separated tire…
Just some thoughts from the limited info you gave…
A vibration can be caused by a lot of things, like a bad tire, out of balance tire, bad suspension parts, ect.
but as far as your so called hop it may be from a bad shock/strut. Or something that they call “the death wobble” beginning.
Dodge Wobble | Death Wobble and How To Fix It - Death Wobble Causes – KevinsOffroad.com
I suggest you bring it to a good suspension shop and have it looked at.
Good ideas above. Good places to start the investigation. After that, does tire tread show any unusual wear patterns? Different that the other tires?
