2000 toyota 4runner code P0420
I am trying to troubleshoot a 4runner with 135k miles, auto, 3.4 V6 California emissions.
This is the freeze data:
PID Description Value Units
0x02 Freeze frame DTC P0420 -
0x03 Fuel system status Closed-loop, using oxygen sensor feedback to determine fuel mix -
0x04 Calculated load value 34.12 %
0x05 Engine coolant temperature 197.6 F
0x06 Short term fuel % trim - Bank 1 0.78 %
0x07 Long term fuel % trim - Bank 1 3.91 %
0x0C Engine RPM 2287 RPM
0x0D Vehicle speed 68.97 MPH
0x0F Intake air temperature 95 F
So far the front and back Ox sensor was replaced and the MAF cleaned to clear a P0171 code. Thank you for your reply,
Has DTC P0171 stayed clear after a 2 trip minimum? Did DTC P0420 come back after it had been erased? The freeze frame short and long term fuel trim is way out of wack. The PCM is trying its best to lean out the mixture but is close to its limit. You will have to find out where the extra fuel is getting into the engine – think leaking fuel pressure regulator, stuck fuel injector, leaking fuel injector, MAF out of calibration, etc. I would be striving to get the long term fuel trim close to 50% before I would condemn the catalytic converter. Can your scanner read the activity of the A/F and o2 sensors? If you have the equipment, use an dual trace oscilliscope to monitor the A/F and o2 voltage wave forms and see if they are similar in rich-lean-rich crossings.
My research has led me to understand that DTC P0420 will be set if the A/F sensor and the O2 sensor transistion at the same frequency. The DTC description is sort of ambigous regarding the A/F sensor and o2 sensor remaining constantly at one value i.e. the wave forms are the same but both are not transitioning.
Keep us in the loop as you resolve this problem so we can learn more from your experience.
hello, here is an update to the truck’s situation. After cleaning the MAF, the long term fuel trim went down. I went trough the repair records and some maintenance was pending, the air filter was not replaced for almost 60 miles and almost 70 on the fuel filter. This one I have to tell, do not try to remove it without a lot of PB blaster and a very good line wrench - I borrowed a snap-on. Jack stand the driver’s rear tire for clearance and remove the plastic cover. The car feels like brand new and fuel trim looks much better now. I think that the converter is gone, too much raw gas. Thank you for your reply.
My toyota highlander HYBRID LTD with 201K miles produces codes indicating 1. catalyst system efficiency below threshold P0420, P0430. Repairs cost 5K. Is it worth doing this repair if it does not last more than 2 years given we are at smog check point now and it will not pass. The next smog check is in 2 years time in CA. If it does not last for 2 years thats a total waste. Would yiu guys know if this repair or replacement of catalytic converter will last another 200K MILES?
Aftermarket catalysts will definitely not last as long as the original parts
That said, if there’s no problems existing that caused the original catalysts to fail . . . a big IF, imo . . . then there’s no reason to believe the replacements won’t last 2 years
Burning excessive engine oil?
Persistent misfiring?
Breached head gasket?
If you rack up 200K in five years, yes, the replacements will probably last that long
If you rack up 200K in 10 years, I wouldn’t expect the replacements to last that long
How old is this car, anyways?
At 201k already, the car will probably be in very marginal mechanical shape at around 400k, no offense intended. Besides the cats, any car is going to require a lot of money in repairs and maintenance if you keep it as long as you seem to want to
+1 - Find the cause of the premature cat failure. I’ve never ever had a cat fail on any vehicle I’ve owned and some of those vehicles went well past 300k miles and a couple past 400k miles. Cats should las the life of the vehicle.
