I have a 2000 Honda Civic coupe. Car will not turn on or click at all. I tried jump starting it. But car will not receive anything. Help me!
Check if fuse #41 BATTERY 80 AMP is blown in the under hood fuse box .
I will check that tonight. Thanks
So I checked my fuse box and I checked that fuse in specific with a light tester. And one side turns on only. So I suppose that means the fuse is no good. I removed the fuse. And tested the box. And only one side turned on and one didn’t. Does this mean that my fuse box is no good as well?
You need a good fuse to send power to the second terminal.
What blew the fuse? Did you connect the jumper cables backwards?
Tested my fuse again. And it was my 80AMP FUSE. I changed it and car started up right away. Thanks for the help
Well done!
