The clutch pedal goes all the way to the floor without engaging the clutch. Is this just a linkage?
The clutch in your vehicle is operated hydraulically. Check to make sure the clutch master cylinder has fluid in it.
The clutch cylinder is located next the brake cylinder on the fender side…If it’s empty, the system will have to be bled to purge the air…(and the leak found and repaired)
Turns out the linkage under the dash broke. Going to the salvage yard tomorrow
