OK GUYS I REALLY APPRECIATE YOUR HELP AND ADVICE ON THIS.
PROBLEM IS WHEN I TURN OFF THE CAR RPM METER STAYS FROZEN, ODOMETER DISPLAY AND CLOCK GOES DEAD, AND IF YOU TRY TO LOCK THE CAR FROM THE CONTROL CONSOLE IT DOESNT WORK, FINALLY IF YOU TRY TO ACTIVATE THE ALARM WITH THE KEY IT GOES CRAZY.
NOW HERES THE TRICKY PART I HAD THE PROBLEM BEFORE, TOOK IT IN AND THEY REPLACED A 20AMP FUSE AND IT FIXED IT , I ALREADY TRIED THAT BUT THE PROBLEM PERSISTS…INTERIOR LIGHTS WONT WORK EITHER, CAR STARTS FINE. I HAVE TO UNPLUG BATTERY BEFORE I LEAVE IT PARKED.
PLEASE HELP!!!
THANK YOU.
PS 99 GOLF OLDER MODEL THIRD GENERATION. BEFORE THEY INTRODUCED THE SLICKER LOOKING ONE.
