1999 safari 4.3L NOT STARTING - checked and found that the safari will turnover but will not start. I checked for sparks and find it ok. Checked fuel pressure and found it ok. Checked for codes and found no codes (but if I remove the connection on the throttle position sensor - the Safari will start and run ok !! So I remove the complete throttle body and replace the throttle position sensor and also replace the idle air control and clean the throttle. Re-install everything back and test but it wil not start and run. So again, I remove the throttle position sensor and the car starts. Do not know what to do!!! Thanks, D.
Cougar
2
Check the voltages on the TPS and see if they are where they should be when trying to start the car.
Related topics
| 1999 GMC Safari will not run | 2 | 710 | December 31, 2007 | |
| 1999 Safari van doesn't start well | 8 | 937 | May 1, 2009 | |
| 1998 s10 4.3l vortec throttle | 4 | 648 | August 22, 2008 | |
| TPS vs Throttle Stop? | 19 | 4784 | May 13, 2009 | |
| 99 rav 4 cold start | 5 | 1397 | July 31, 2010 |
