auxillary idle speed control. What is the most likely part replacement require?
This code usually points to a short within the Idle Air Control motor. This can be a short to power or a short to ground. This code can also be caused from a short to and from the IAC motor, or form a bad ECU. But 99.99% of the time, it’s because of a defective IAC motor.
