My 98 Sienna clicks when it won’t start. I changed the ignition switch, the battery,
starter relay, key an tumbler, and I’ve also taken the starter off and had it checked (It checked out ok)
What should I check next?
Make sure all of the cable connections are clean and tight. This includes the ground connections. Loose or corroded connections, anywhere within the starting circuit, can cause starting problems.
Some times battery cables will get corroided under where plastic,rubber covering starts.
Use a knife and cut 2-3 inch slice and look for dirty wire under coating
I’ve changed battery cables. Cleaned post and changed post connections.
