1998 Toyota Corolla headlight assembly replacement
Pick up the Haynes manual for the car. It will probably show you a step by step sequence of screws or clips or brackets or thingamajiggers to pull out. Easy. If instead, it shows that Toyota made the job stupid hard, then pay the mechanic.
