Overheating in stop and go traffic or when pulling small hills. Manifold intakes have been replaced. Water pump too. Radiator flushed. NOT losing water. Can this, nonetheless, be a head gasket problem?
Could be or could be a problem with the fan.
Thanks for your reply. Both fans run when I turn on the A/C. Haven’t been able to pull over and check while it is overheating. I usually turn on the heater full blast and try to find an open road. Henry
