I’m a bit concerned about my faithful old 1997 Honda Accord DX.
I noticed a particularly slow start a few weeks ago, so I went to Batteries and Bulbs for a quick check. The battery, which was a little over a year old, was already half dead. They swapped it out under partial warranty in case that was the cause.
This morning - same deal. It turned over 4-5 times with a particularly large squeal in the middle of the cranking, but it finally started. I drove it ten minutes and parked it at my normal mechanic (met a friend there to drive her to work, since her Honda has a check engine light on) and it cranked up immediately there. Turned over once, and fired right up.
The last time I thought I heard a funny noise on starting and took it to get checked out (and get an oil change at the same time), my mechanic swore everything was fine. In fact, he said “Your car is perfect.” I’m concerned if I take it in without having some suggestions on what to check this time that I’ll be dismissed as a car hypochondriac.
The car has 222K miles on it. Last tune up was around 200K miles, last timing belt change at 190K miles.
