Start it up an put it in drive , nothing in till it comes below 1000 RPM.
Then very slow
Suspect your transmission is worn out, usually due to lack of maintenance, changing the fluid every 30-50,000 miles.
Could you explain exactly what that means?
You really need to elaborate on this because I don’t understand the complaint either.
