I have to replace the muffler, the pipe btwn it and the convertor, and the tailpipe every 3 years religiously. Most trips are 30 -50 miles, so I would think that the water is being blown out of the system. I have owned this truck for 13 years and I am about to replace these components for the 4th time. Why is this truck rotting out these pieces so quick? Thanks
Are you buying and installing aftermarket exhaust systems? Most are good, BUT if not stainless steel and you drive in a salted winter environment, some mufflers and pipes won’t last past three years.
Are you the second owner? 1995+13 = 2008
The mufflers are supposed to have a small drain hole in the after end at the bottom for the condensation. During a warm up idle have you seen any moisture drain there?
Has the converter ever been changed/damaged?
Are all muffler bearings properly lubed?
Serriously, tell us what is happening to these pieces,holes,loud muffler,broken bolts? Is it always in the same places
I have been using Walker muffler and pipes because I have had good luck trading in the muffler on the lifetime warranty deal. I still have to pay for the pipes, clamps etc… It is the tailpipe that usually goes first, a few months later the extension pipe rots out and the muffler starts bouncing around. You cant seperate these damaged pipes without damaging the muffler. The muffler has never rusted completly through, but my local parts store always honors the warranty.
I do see the moisture leaking out the drain hole and I occassionally poke a piece of wire thru the hole to make sure it stays open.
I am in southeast michigan where there is a lot of road salt applied, but I do rinse the entire underside of the car every few weeks to try to remove as much of the salt as possible. Maybe I should stop hosing off the exhaust system.
A long time ago I purchased a new 1978 subaru with a complete SS exhaust system that lasted longer then anything else on that car. The fenders, floorboards and ehaust hanger attachment points to the body all rusted after 5 years, but the car purred like a kitten. The SS seemed to want to last forever. Can I get SS pipes and mufflers for a 95 S-10?
I had the same problem with my wifes’ '95 civic. She only drives 9 miles to work, the exhaust never really warmed-up. I put at least 10 pieces of exhaust pipe/muffler/etc on it since new. I changed to an aftermarket system from the CAT back two years ago . . . the whole set-up was much thicker walled steel, painted and nice exhaust tip. It still looks new after almost two years. It’s a Pacesetter. Yes, it’s a little louder, but not objectionable. Whole thing cost less than $200. I’ll bet that a SS exhaust would be a lot more than $200. Rocketman
Exhaust systems rust out from the inside out LONG before road salt has any effect on them. Driving 10-20 miles each trip should be more then long enough to burn off any water in the exhaust. 3 years however is about all I’ve ever been able to get out of a exhaust prior to 1997 when companies started to use stainless steel to meet the new 50k emissions warranty. Now I’m getting about 6-10 years out of an exhaust.
I spent 40+ years in SE WI and I would say this is typical for those parts in that climate. You could step up to a thicker gauge pipe or SS and get longer life but in my experience you’re getting typical life out of those pipes.
I would skip hosing off the pipes in winter. I suspect you are doing more harm than good. Many people subscribe to the idea of just leaving the salt alone as long as it’s below freezing and it does less harm that way. My cars seemed to last longer if I ignored them in winter and only washed them off when it got warmer. YMMV.
If you’re going to continue doing exhaust work and using saddle clamps, you might consider investing in a pipe expander and a right angle “grinder” with a cutoff wheel. They are replacing the mufflers, great! But if you have to save them, it’s not hard to separate the parts by grinding through the clamps and along the pipe overlap. Then split the halves off the muffler extensions and use the pipe expander to return them to the correct diameter. BTDTBTTS. I did my own exhaust work for decades but finally decided I had my last piece of rust in my face from exhaust and take them in now. The local shop does great work and I have a coffee and read a mag while they bust hump.
Check around for a lifetime warranty. A local shop that bends their own stuff replaced a muffler and pipes, even welded the catalytic converter back together for less than I could get parts for. I had 2 replacement mufflers over the next 8 years, one was free one was 12 bucks for new clamps. Can’t beat that!
I suggest looking for stainless steel exhaust components. I also subscribe to what Twin Turbo said about washing the underside. While the wash places will tell you that it prevents rust, in truth it drives water into crevaces and areas that would not normally be subjected to soaking, and if it’s cool out the wet stays and begins to cause rot. It’s long been my belief that washing the underside of a vehicle promotes rust rather than preventing it. Others will disagree, but that’s my opinion.
