1994 Jeep Wrangler brakes fail to hold in reverse
Good story with happy ending. My 94 YJ has fuel injection, stock,
even though it is a minimal type it overcomes the steep
incline/carburetor problem. I have had to replace the stock plastic
fuel lines due to a “flooding” situation - raw gas flooding the
engine compartment. Fortunately that happened near an Ace Hardware
where I could buy a rubber hose to bridge the gap. I later replaced
that with high pressure woven fuel lines just to be safe. Also This
model Jeep has a built - in problem with failing parking brake.
There was a recall so dealer will replace the assembly no charge,
but the design is the same so it continues to happen - but the
dealer just does a "recall re-do"each time . Especially scary at
the boat ramp when you hear the darn thing release and start moving
backward.
Thanks for the reply, someone suggested the proportionalizer valve
may be the cause of my problem - I’ll try that next.
