Okay, so after going through two batteries in two weeks its been decided that the alternator is not working.
 I cannot afford the risk of being stranded at a shop with a broke truck while waiting for a mechanic to check everything.  I have been told that I can just pull out the alternator and take it in by itself to get it looked at.
 First question, can a mechanic check an alternator that isn’t attached to the truck it belongs to?
 Second question, how do I get the alternator belt to release tension?
 Here is a link to a series of diagrams, the belt diagram in the lower right for the 7.5L matches what I’ve got to work with.  I’ve tinyurl’d the really really long url below.
 http://tinyurl.com/269q528
 There IS a belt tensioner but it doesn’t control the tension to both belt systems.  I cannot find any instructions elsewhere in the Inter-tubes that tell how, specifically, the belt to the alternator is tensioned.
 Any help?
So, is it the 7.3 diesel as indicated in your title ?
Or is it the 7.5 460 gas you speak of in your text ?
I miss keyed. I have a 7.5 but I bit the bullet and just started to tinker with things until I figured out which bolts to remove and in what order.
Thanks though.
