The igniter on the distribuiter keeps going out. Is the a better fix for this besides replacing the igniter all the time.
[b]Igniters/ignition modules can be damaged if there’s high resistance in the secondary ignition components.
So, if it’s been a while since the cap, rotor, wires, and plugs have been replaced, you might consider doing that to see if the igniter lasts longer.
Tester[/b]
