Makes sense to me. I agree the thermostat is very cheap anyway. I think my plan of attack is
- replace the thermostat
- bleed the cooling system
- if necessary flush the coolant.
I think we have a winner. I did replace the thermostat and it was stuck. I also ran the engine afterwards ad it read overheating at idle within like 3-5 minutes. However, nothing was hot on the car. The intake manifold wasn’t hot, none of the rad components were hot. The valve covers were warm but that was it. i’m thinking a sensor is playing shenanigans. I disconnected the two wire sensor (twin turbo identifies as gauge sender in post 37 pic 1). the fans turned on immediately (yay working fan) but the gauge activity remained the same, it steadily climbed. not sure how if that’s the gauge sensor. So I’m going to reasonably assume the car’s not actually overheating. I am going to bleed the coolant system since i opened the system anyway to change the thermostat. Should I assume the coolant sensor mentioned before in that pic needs replaced? or do i have some kind of wiring issue if it’s climving regardless of whether it’s connected or not? But the fans do kick on if it’s disconnected.
Replace ALL coolant temperature sensors . . . they’re cheap enough, and hopefully your problem(s) will disappear
I appreciate the response and i mean no disrespect but I’d like to properly diagnose the problem to the best of my ability. I don’t want to throw more money at this than is necessary. I know the sensors aren’t super pricey but I’m also working on an engine swap on my GF’s subie that’s eating my finances.
The sensor next to the thermostat with one black wire and one yellow wire is the coolant temp sensor for the computer. I’m pretty sure there’s a seperate sensor for the gauge.
That would make a lot of sense. that would explain why the gauge made no change when i disconnected the sensor near the thermostat but it kicked the fans. on. I just need to find the other sensor. There is that other “fan switch” in the second pic on post 37. the one green wire sensor. unless there’s a 3rd coolant sensor.
Not sure. Might check out a website like rock auto and see what they list.
This site mentions that one wire sensor might be it. I did replace that before but might’ve been an improper part since the people at oreilly didn’t seem to understand that well.
https://www.thirdgen.org/forums/cooling/528733-temp-gauge-not-working.html
I think the single green wire is for the gauge. You could unplug that bad boy and see what the gauge does.
Yeah, they’re labeled incorrectly in the post with the pics. The one with two wires, I’m positive, is the engine management coolant temp sensor. The green single wire, I’m pretty sure, is for the gauge.
Yeah I can definitely verify through multiple sources that single wire sender is for the gauge cluster. the question is, is the sensor bad or is it a wiring problem. I guess If I unplug it and the gauge spikes then it’s definitely a sensor, if it doesn’t then some wiring goof. I’d assume since it slowly climbs not jumping or anything then it’s probably the sensor anyway but I’ll find that out tomorrow.
Yep, sounds like a plan. Unplug it and see if gauge spikes. I have no idea how to test it, so might just get a new one if they’re cheap.
You are 100% correct, my mistake, I have a question if I may; I just had my water pump replaced and I still have an error message “low coolant”, is this a bad ECTS? I also would
tell you when we hook to my ECU we no longer get fault codes when we clearly have “faults”, last month my BFF scanned and got 2 failed O2 sensors, one up and one downstream, now no fault codes at all, even with the “low coolant” error on the dash. The ECU cant be completely failed or my car wouldnt even run, any ideas? Thanks John
Well I ran into a new probably unrelated problem (go figure) the car is now stalling after a short drive. It will idle pretty much fine bt it seems after driving for a short bit, trying to accelerate causes a bit of problems. I’m going to assume either fuel delivery problem ( looking at the fuel filter for starters) or a vacuum leak somewhere (entirely possible since I took the intake hose off to get to the thermostat something may be loose.)
ok stalling issue potentially fixed. when i messed with the coolant sensor, it wasn’t latched down. I’m thinking it was loose and causing shenanigans. I drove it a couple blocks and had no issues.
Not familiar with your car, exactly, but “low coolant” - there may be a sensor in the coolant reservoir and it may be bad, assuming coolant level is good? I don’t think the coolant temp sensor would monitor coolant level at all.
Well. I believe the problem is resolved…sometime during the overheating process, all the coolant was gone. Iput about 1.5 gallons of coolant in and used the funnel to bleed it out. Now it’s not getting hotter than about 220. and it took it’s sweet time and a good 10 min drive around town to get that hot.
Yeah I’m pretty much going with resolved. I’ve been driving it pretty extensively and after quite a while of driving it will start peaking around 220-240 (assuming that’s what 3/4 of the gauge means) and sometimes go just over that line, but will start coming back down to 220 shortly afterwards. It’s not come close to red lining at all. When it get’s to it’s “max” I don’t hear coolant boiling or any other strange sounds. I’m assuming at this point it’s just running like any typical old engine of the time. I do have the newer fan switch which is supposed to turn the fan on alot cooler (i believe 190 if I’m not mistaken) so once I get that on, I’ll see if it runs cooler.
