1991 Cadillac Eldorado - Starts then dies
My caddy starts up then dies its says cautiously theft issue starting disabled
You probably have a problem with your VATS (Vehicle Anti-Theft System)
GM vehicles had problems with this. there is a way to bypass the VATS system. there are plenty of videos online showing you how. just be aware you won’t have a working alarm system.
The VATS system: The GM VATS (Vehicle Anti-Theft System) system uses a black pellet in the metal part of the ignition key. The VATS decoder send a ‘key OK’ signal to the PCM/ECM when the proper key is detected. Without this signal, the fuel injectors will shut down within the first 3 seconds.
The VATS problem: The VATS system may become problematic with age. Increased wear, and higher resistance due to dust and corrosion can lead to ignition key readings that prevent the vehicle from Starting
Could be the VATS anti-theft system. Try a spare key or check the key resistor. You may need to bypass or fix the system.
See if this solves the problem.
