My 89 Ford festival will not stay idling. It runs good if I run it at about 3 rim I’m guessing. Is there a possible vacuum leak? It try to idle on start up
OK, we know the car is a Festiva that won’t idle. That’s all you told us that I can understand, as I don’t know what 3 rim is. Is that 3000 rpm?
From that we all will be guessing as to the problem just like you. sure, a vacuum leak can cause that… But so can a hundred other things.
If you’d like a bit more help, we need to know a lot more about this car.
Sorry I was tired when I wrote that. I meant to say that my 89 Ford festival starts but will not stay running for more than a few minutes. It’s getting gas. Was wondering what could be the problem
