1988 Mercedes-Benz S-Class won't start in the morning
having problem Park my Car at nite in the Morning Car does not start Battrey is Dead. something is Draining the power overnite
That is a reasonable assumption, though it could simply be a battery that’s too old to (you didn’t say how old your battery is). Take your car to a local, well recommended, independent mechanic for diagnosis and repair
check to see that the trunk light or glove box light are not staying on.
The bulb in both should be cool when you open either. If the light bulb is hot then the switch is not shutting off that light.
Yosemite
Ask your shop to do an alternator/battery system test, and a phantom current drain test.
