I suspect 2 things. The resistor wire is intermittently screwing up after things get warmed up/hot. Is the coil wired properly? You need not go the HEI route necessarily. Try this site: www.pertronix.com This system converts your already-existing didtributor to a solid state electronic ignition. Once on the site, click on “Ignition”, then “Ignitor”. I use this system in my '71 Chevy van, 250 c.i./ L-6. It has worked without fault for ten years. It’s a simple swap-out of the points for a small module that uses the same existing hold-down screws and works on the Hall Effect-type of ignition. Better, quicker starts, completely reliable in all temperatures/weather conditions in the middle of the Colorado Rockies, etc. My original point set-up was eating points about every 300-500 miles. Removed the part of the resistor wire that does the resistance work. Replaced it with a ceramic block-type resistor mounted on the firewall with one large sheet metal screw. Mine happens to be a Chrysler block resistor matched closely to what Chevy says should be the resistance specifications. I believe that Americam Motors block resistors would work, also. Perhaps a Ford-type resistor block? End of points burning up. But I got sick and tired of bending over the didtributor to re-adjust the points every 10K miles or so and installed the Pertronix system. Better starts, better performance, no more occasional backfires due to the vacuum advance, etc.
profhandy
41
Related topics
| 1960s vintage technology - how to troubleshoot a no spark condition | 46 | 89714 | September 7, 2012 | |
| Can't get spark in old GTO | 28 | 23422 | November 16, 2011 | |
| Misfire on Cylinder 4 - Coil/plug is good, but voltage to coil is high? | 43 | 15112 | August 27, 2008 | |
| 1965 T-bird will turn over, but not fire? | 24 | 11913 | January 15, 2012 | |
| Diagnosed Misfires | 77 | 5791 | August 21, 2015 |
