Where would I find the ignition condenser? Is it on the distributor? As for the engine running, it (as well as all electrical systems) simply stopped. Regardless of the position of the ignition key, the lights no longer work nor is there any ‘click’ when trying the ignition key. So testing for spark is not an option yet. And yes, I do have gray hair and it took 62 years to grow it. I have a new voltage regulator to install as part of the process of elimination of “possibles.” I’ll do that and post the results.
Installed the voltage regulator and it may have had an effect. Afterwards I started testing for power using a simple ground/live tester with a light in the handle. There’s power to the starter, power to the alternator, and some power in the cab, especially the gauges (after-market type mounted under the dash), but very minimal power to one fuse in the fuse box (I have replaced all the fuses with new). I have attached a picture of 2 molded-plug connections that I unplugged and tested, then plugged back in firmly. Now I have the cab light, the parking lights with rear tail lights but no headlights although the ‘high beam’ indicator in the dash works as does the floor-mounted switch to dim the lights. Tail lights work as well with the light switch in the ‘headlight’ position. Most of the fuses (since I diddled the plug) seem to have power. Now when I try the ignition key, a red indicator light comes on indicating my attempt, but nothing at the starter. I don’t know if this picture will give an ideas but now it seems that perhaps ‘whatever’ is wrong may be in the cab under the dash. I have no idea what’s there but it looks like wire-spaghetti. I have repeated my post to TechMech here including the attachment.
The engine still does not turn over and still no headlights. That one connection that I pulled and tested though seems to have been a part of the problem as well. Makes sense that there may be another somewhere but other than in the cab, I have no idea where to look even in the cab under the dash. Its “guess and by golly” time. Any ideas?
I looked up the condenser and now I know where it is. Duh! Its good. And I have power to the coil, the starter, but no response other than a power draw indicated by the gauges mounted under the dash and a red light that comes on when I turn the key to start the truck. With the key in the “on” position, I have power to the coil. When it is off, I do not. I figure that’s normal. Still no headlights and no starter action.
At this point here’s what I have working. The indicator lights on the after-market gauge assembly mounted under the dash. The dome light comes on. The parking lights work as do the tail lights. The turn-signals work but the right front does not but the rear right does. The bulb is good up front. The windshield wipers came back to life. The heater fan came back to life as well. I seem to have power at all critical locations in the engine compartment, the coil, the starter, the alternator. I get a ‘draw’ on power when I try to engage the starter but no response from the starter. No headlights either though I have replaced the bulbs there as well. So I have power to most of the system (which is a long way past where I was) but not and response from the ignition or the starter or the headlights.
Now I need to know how to ‘jump’ the starter to see if it works. I have a central post and a positive and negative terminal to the left and the right of the main central terminal. If I can short the starter there and it works, then perhaps the problem is inside the cab under the dash? Thanks for all your help (everybody)!
