For a little while I have been noticing an odd noise from the front driver side tire. About a year ago on two different occasions I heard a sound when I turned the wheel somewhat sharply that sounded like a clacking noise almost like gears slipping. It only happened for a few seconds and stopped but has never done it other than those 2 times that I am aware of. This is my wifes everyday driver, so I don’t always hear the noises.
Recently it started making a sound that to me sounded very similar to a wheel bearing going bad. I looked into it a little and drove it and decided to change it even though it didn’t have all the “symptoms” of a wheel bearing (louder when turning away from that side, quieter when turning towards that side, play in the wheel). After replacing the hub assembly it didnt make the same noise, but made a different noise that was from the shield on the back side of the rotor rubbing against it. Took it for a drive thinking that I fixed it only to have it start doing it again. After listening closer it sounded like a metal rubbing against metal sound, sorta like a brake pad dragging on a grooved or rusty rotor. I inspected the rotor and all i saw as an issue was on the inner side of it there was a ring of rust on the inner and outer edges, and it was wearing the pad to have beveled edges. I replace the pads and rotor, and it still makes the sound.
I am down to two options that I can think of trying but do not want to really try either one because of the amount of money I have already put into it.
- I have thought about replacing the brake caliper, but it is an additional $130.
- I have thought about replacing the CV Axle, BUT the boots are in excellent shape and it cost in the range of $90.
It doesn’t make the noise all the time, and sometimes it is worse when turning to the right, and other times there is no change regardless of the direction you turn. When it does do it, it feels almost as if the car is dragging and pulls to the drivers side.
I am really at a loss here and don’t want to keep narrowing it down because I have misdiagnosed the problem twice now, and was really confident in it being the wheel bearing.
