OK, after having let this car sit in my yard for way to long, I’m back at it. Here’s where I am.
-Mostly, the car will start, after a few attempts, but dies right away.
- I cleaned and tested the EGR valve. Wasn’t terribly dirty, and, connected to a 12V power source, it works fine.
-I have a new O2 sensor, but the dirty one is still on the car, because I’m thinking if I put a new one on right now, it’ll just get clogged like the old one.
I decided to take a look at the spark plugs. I put new, honda spark plugs in the car in October, and, considering I wasn’t driving it much and that the car started acting up in Jan or Feb, they didn’t get much use. But they were coated in sooty build-up.
Since I had been too lazy to throw the old plugs out, I put one of the old plugs in the #1 cylinder. And it worked like a charm! For a few minutes, anyway. The car seemed to run great, and I could even put it into R and D. But then it died. I started it back up, it ran, but just a short time this time, and died. And after that, nothing.
So I took out the remaining 3 plugs, and put in the old plugs. No change. Start, sputter, die.
I took out spark plug #1 again, and, guess what? It was black. I cleaned it real quick and threw it back in. Car started, ran fine for a few seconds, then died.
OK. So the part of the problem with getting the car running is that the spark plugs are just covered in black gunk! But…what’s causing the black gunk?
I haven’t personally checked the timing, but the dealership claims they did, at the crank and the cam, and said it was fine.
So what’s causing the build-up?
