Done! Old ATF looked clean and redish.
Transmission runs perfectly!
Several stat bloodeliveries and an emergentransport where the hospital asked to push it.
Even then I still try to be gentle on thengine.
Now doing my OCD oil change withe motor oil draining all night.
Everything cleaned with toilet paper. New oil filter oiled and installed.
3 quarts of Mobil1 Full Synthetic 0W-20 Hybrid oil measured into two 5-qt containers to quickly fill if an early morning emergency. (Recently was called at 0420 during an OCD change.) Luckily remembered to screw the pre lubricated oil plug in before adding the oil.
Toyota âWorld Standardâ bought at a Toyota dealeright on the way home from a mountaihospital.
Alsoil filters < half the price of Lexu$.
Loaned the torque wrench ando not knowho stilhas it. Nothing leaking - so far.
Shall screw in thengine oil plug and install Mobil1âs 0W-20 Hybrid.
Lexuspecifies 0W-16 buthe 2023 RX350 already has 67k mostly Interstate miles.
Hate thengine temperature and fuelevel segment readouts.
Normal engine operating temperature displays four â â â â
What is â â â â â ? (Have never seen.)
Letting oil drain over night from a vehicle is not just different . It is unnessary and could cause engine damage . Just another goofy idea from this attention seeking fool.
One can only hope that someone does not think RG is a valid source of information.
No morengine damage than parked the same period without running.
While I am sleeping a little more dirty oil drips out beforefilling withew oil.
(Years ago saw the Letsuck technician puthe oil plug back in before the dirty oil was finishedraining.
They are in a hurry.)
The horizontal oil filter cannot be filled with oil before screwing on.
Have filled thext filter so thathe oil soaks through between paper and can.
These filters are too small.
Arenât you glad you came to Car Talk to seek approval to perform maintenance on your vehicle? Now you have more transmission maintenance experience than most people here.
1 1/2 quarts poured into in each container? The engine oil capacity is 4.8 quarts.
UH-OH. I put in what Lexus dealer said - 6 qts. engine oil. (3 quarts in each 5-quart bottle makes it easier to pour in without spilling.)
(Manual 5.6 qts I recall?)
Glad thathis transmission fluid can be moreasily changed compared to the previous RX350 transmissions.
Drain old, inject new until it begins to overflow the filler opening.
$19.25/quart.
Did not realize it contains gold powder.
Not checked until off the ramps and level.
An inch above the top dot on the dipstick!!
I thoroughly cleaned the oil plug and arearound it andrained a QUART into an empty 5-quart container.
Shall use the drained oil through a paper towel next OCD change.
Paper towel can break down and contaminate the oil⊠I for one donât want contaminates going through my engine bearings, piston rings etc, that is one reason for changing it to begin with⊠But that might just be me⊠Kinda pointless to do a OCD oil change just to start off with contaminated oilâŠ
