Join the Car Talk Community!
Discussion Rules
Sign In Register
Manual Transmission for Dummies!
edited January 2012 in General Discussion
Okay so a friend of mine bought a Nissan Juke...I'm not a huge fan of it. I think the front end of it looks like an insect but it seems to suit her fine. One problem...The Gear Shifter on it! My friend couldn't figure out how to put it in reverse so she calls me over and I sit in the car and I know how to drive a stick shift. And so I start the Juke up and I'm looking at the gear shifter, there's a button on the shifter and I wonder what that was, and I try to put it in reverse (its a 6 speed so reverse is to the left of 1st gear, that much I know) and nothing happened. I was like "What in the world?" So I thought about it for second and decided to see what would happen when I push the button on the gear shifter as I was shifting the car into reverse again and ta da it goes backwards...figured it out. Why do manufacturers do this? Is it a precautionary thing? Design or what?
  • Yep, precautionary - different cars have different kinds of interlocks, or none at all. My '65 Mustang 4 sp had a 't' shaped handle below the knob that I pulled up to get reverse.
  • I guess I was just used to driving a 5-Speed Standard H with Reverse being located beneath 5th gear and no buttons on the gear shifter lol...
  • This reminds me of how one shifted the Chevrolet and GMC trucks that had 4 speed transmissions and manufactured before mid 1947 into reverse. Low was on the top left; second was on the bottom left; third was on the top right; and fourth was on the bottom right. To shift into reverse, one put the lever in second gear position and pulled up on a lever on the gear shift.
    As I remember, on the old VW Beetle, to shift into reverse, one pushed the shifter down and pulled it back toward the driver. I guess this is a modern day Nissan version of the old GM truck transmissions and the VW transmission.
  • Is this why we're supposed to read the owner's manual? :P
  • Yeah I was going to read the owners manual if I didn't think of pushing the button while shifting into reverse. The reason I thought of it was it reminded of the time my stepdad owned a Volkswagon Cabrio and I borrowed it one day when my old car was in the shop and same situation...reverse was on the left of 1st gear on the gear shifter instead of below 5th Gear or on some 4-speed models, to the right side of 4th gear and I had to read the instruction manual as to how to put it in reverse...On volkswagons you have to push the gearshifter down in the center then shift to reverse. And the Juke kind of reminded me of that except you have to push a button instead of pushing the gear shifter down in the center. As for shifting gears in older cars...My Dad always called it "Three on the Tree!" Thank god I didn't own anything like that lol...
  • I have a six- speed Nissan Versa and reverse is up to the left of first, but mine has a collar that you pull up with two fingers to get into the reverse gate.
  • "As for shifting gears in older cars...My Dad always called it "Three on the Tree!"
    The column shifter, or "three on the tree" was introduced in 1938 as an option on a few cars--the 1938 Pontiac being one of these cars. By 1939, it was standard on most cars, although it was an option on the 1939 Chevrolet and I don't think it was available on the Ford until 1940. At any rate, the column shift was considered a real improvement over the floor shift. Suddenly, in the 1970s, the manual transmissions went back to a floor shift. Yet, there are those that think the automobile industry has made prorgress.
  • I have a Nissan Versa too but opted to get the Automatic instead of the manual because at the time I was living in a city where you had a lot more stop and go traffic. Now I live out in the country and there's very little traffic and either type would work for me.
  • edited January 2012
    Yes, this helps prevent shifting into reverse accidentally.
  • This is yet another interpretation likely from marketing people of how to do it. It's intended for customer satisfaction but that does not always connect.
