It has to be positive pressure. I think the vent line is completely closed probably in the canister. This causes fuel to be pushed out of the tank through the return line from its tube in the bottom of the tank to the canister.
Let the gas tank pressurize up and disconnect the tank vent line at the canister.
If it hisses as you slide the hose off the tube, the canister is bad and shoud be replaced.
If it does not, there is an obstruction or kink at the tank or the vent line.
Tom and Ray may be right about the need to drop the tank. They went off target about it being a vacuum issue.
My bet it is a bad evaporative (condensing) canister.
They don't last forever
Comments
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like"the intricacies, the gives and takes, the wherefores and why-nots, can become a veritable pas-de-deux of breathtaking speculation, interwoven in such a way that apologies or gestures of doubt are rendered unnecessary."
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikePositive pressure is relieved through the purge valve in the charcoal canister. If the purge valve opens, the pressure is then blocked by the TVV (Thermo Vacuum Valve), which opens when the engine temp reaches about 130F. If the purge valve and TVV are both open, then the pressure is blocked by the purge port in the throttle body which opens when the throttle is opened past a certain point. If all of these valves are open, then a blockage in any of the hoses between the charcoal canister and TVV, or the TVV and the throttle body, could be the problem. There is a very remote chance that the throttle body port valve could be plugged.
It might be possible to work back from the throttle body, removing one hose at a time, to locate the source of blockage.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeIt could be that the mechanic pulled the fuel lines to clear them and then put them on backwards. The only way I figured out the problem on my truck was to pull the lines and stick the air compressor nozzle on them one at a time. I was troubleshooting it as though it was a blocked line, and was surprised to hear the air coming out of the wrong place. Might be a similar issue here, if the mechanic hooked them back up wrong after removing the "mud chiggers". (I suspect it was a different source of fuel line or vent hose blocking, but either way the same mistake could have been made.)
- Spam
- Abuse
- Troll
