2007 Jeep Liberty - Help ! Can't get the oil dipstick back into the tube! Goes in about 3/4 of the way and jams - feels like it's hanging up on something. This is what I did: pulled it out, wiped it off, slipped it back in, pulled it out again to check the oil. Now it won't go back in. (No - I didn't put anything else down there!) The dipstick has this little twisty bit at the end - is there a valve in the tube it's supposed to slip through? This is my only car and I travel to work. Can I drive it without a dipstick?
0 •
Comments
Try rotating the dipstick 180 degrees and then try again to insert it.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeYep, ll you have to do is twist it.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeYou can still drive your Jeep even without a dipstick.
- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeWhat happens when you run the engine for 5-10 seconds, is there oil under the car?
- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThat is expected. If you can't get it in all the way except for about 2 inches, the dipstick will not get wet. I wouldn't worry about that at all for now. It will only become a problem when you really do need to check your oil level. Try pushing something like a thin wire through the tube and see if it hangs up in the same place. It has to be thin enough to pass through a hole in the blockage that the dipstick can't, but it still mist be stiff.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThe reason some dipsticks have a "twisty" look is so that they can make compound bends in the tube. A regular, old-fashioned flat stick can only follow simple bends.
CSA
- Spam
- Abuse
- Troll
- Abuse
- Troll
