Join the Car Talk Community!
Discussion Rules
Sign In Register
steel seal , does it really fix a head gasket
i own a 98 plymouth grand voyager , i noticed a leak of antifreeze from the head . does products like steel seal really work?
«1
Comments
  • edited February 2009
    A leak from the head or the head gasket?
    Big difference when it comes to getting educated answers.
    If it really did work, I don't think you would see all those head gasket replacements done.
    Edit: I should have noted that a number of materials may help in a head gasket situation, but they are not a proper fix and any real head gasket fix is to replace it while checking to make sure the mating surfaces are flat. In the case of a old marginal car, I might give them a try.
    I don't know which ones are better than others, so if Tester says it is one of the better ones and he uses it, I would consider that a good endorsement.
    This stuff is just sodium silicate, ie: Water Glass/Liquid Glass, (look it up). And it does work. Only these guy's figured out how to market it with a fancy name, and charging three times what it would cost to purchase a bottle of the stuff from a chemical company or pharmacy.
    As a matter of fact, there's a vehicle in the shop with a blown head gasket right now. And it's not worth the price to replace the head gasket. So, the sodium silicate's going into the cooling system to stop the leak.
    Just to let everyone know, the sodium silicate stopped the head gasket leak. No more overheating, no steam/water out of the tail pipe. I called the local pharmacy and they ordered up a pint on the stuff for $20.00. Much cheaper than the Steel Seal.
    So if anyone has a head/head gasket/block coolant leak, and the vehicle's not worth the price to repair it properly, and you need to get back on the road long enough to get a replacement vehicle, this is the way to go.
    If anyone has any questions, feel free to ask.
    That's pretty interesting Tester, thanks for the info. Rocketman
    Hi I was wonder what specific brand did you get from the pharmacy, or at least the specs. I was looking for sodium silicate, and I get questions on what type do i want. like this link http://cquestchem.com/sodiumsilicate.html is there a difference. Also does it depend on how bad the blown head gasket to the variables in that link.
    Tester, What Do You Suppose The Residual Stuff Is Doing To The Cooling System?
    There are lots of different brands - most of them are around 10-20 dollars where I live - gunk has one too. I've heard to use it properly you should drain your antifreeze, then refill with water and the silicate, then drive for awhile 500miles, then drain and refill with usual antifreeze mix.
    I may have to try it as I have a 10 year old van and its not worth a 1,000 job. What I am wondering is, can you tell if its been done before by the previous owner? And are there some problems you shouldn't use it on? I am thinking of getting a coolant pressure check to see exactly what's wrong, but I'm worried this will put pressure on the old cooling system and make it worse. Trouble is, where I live its not going to be above freezing enough till about another month (or two).
  • edited September 2009
    Hi Tester. I read your posts and you seem very knowledgible. Would this Sodium Silicate be a long term solution, or would it eventually fail? Also, is there any procedure in putting it in a car? Do I just add it to the coolant, or do i drain out the coolant first, then put it in? Thanks
  • edited September 2010
    Hebei Shineyond Metal Products Co., Ltd ,ltd is located in Asia's biggest screen production base.The company is the collection of development, production, sales for the integration of large companies,it have the most advanced equipment, the loom, technical force is abundant, the process of science, quality testing system is perfect, adopts the high quality raw materialsspecializing ,in the production of gabion,galvanized wire, barbecue net,, wire mesh, crimped wire mesh, welded wire mesh,barbed wire, black iron wire ,stainless steel nets, etc. Products are widely applied in industry, agriculture, construction, transportation, stadium, lawn, breeding, mining and other industries. Sold throughout the country and exported to the USA, Japan, Germany, South Korea and other countries and regions.
    www.metal-china.cn is a treasure of Hebei pu electronic commerce Co., LTD. Invested?Mainly for the steel production enterprise, the dealer, the downstream enterprises and relevant enterprises and institutions to provide steel, steel trading online information online, enterprise, and enterprise Internet solutions, steel marketing management software and warehouse management software development etc. Products cover breadth?besides H-beam, deformed steel bar,steel pipe,channel steel,steel strap, angle steel,steel pipe.It concentrated various network products, mainly are galvanized iron wire, black annealed wire,barbed wire,barbed wire,wire rod,welding electrodeand nails,Because of the professional and updated information, market fast speed, the majority of the members and visitors to the attention and affection. In China's steel nets developmentcourse, total absorption member enterprise nearly 10 million.
    The printing machinery network (www.yja.com.cn), founded in 2001, is now the largest domestic printing machinery industry vertical B2B e-commerce websites. Value-added telecommunication business license Numbers for: hubei B2-20050125. For printing and china printing machine related enterprise products trade and information exchange interaction bridge erection. It has comprehensive application foreground and spread value for label printing machine,flexo printing machine.And it is the biggest online printing machinery display platform. The printing machinery network make full use of the advantages of the Internet, distinctive "Network + publications" , facing the whole country and the world, to provide professional enterprise online, offline various forms of professional trade service.
    With the development of science and technology, home theater has become the general population, dvd box set market more active, DVD and CD look similar, they are the diameter of 120 millimeter, usually used to broadcast TV film, the standard definition of high quality music with great capacity data storage usage.
    Along with painting become time pets, all kinds of high quality oil painting receive a kind welcome in the market. Oil painting reproductions also took the eye of collectors rapidly, even strive with Original painting.
    You can into www.oilpainting109.com to find all sorts of painting, here is the supplier for many world gallery, and online gallery, inevitable - the business of the company is special, can take any image and any size for so many talented artists working, company not only selling cheap paintings, but a high quality supplier too.
    We professional wholesale new era cap,the absolute reputation guarantee and the absolute quality assurance. Various of style. Here, I believe you can find yourself like , you can choose and buy online, we will prompt delivery once you pay.
    We give first-class service, you needn't worry about the quality question, our existing items through professional qc personnel evaluation. Ensure the goods that you receive is complete. What do you still wait, please hurry.
    Optical8 is a store specialised in fasionable glasses and cheap eyeglasses.Take some time in Optical8 and you'll find some ideal glasses in style and fashion. Enjoy your shopping!
    cheap ghds
    Cheap ghd straighteners
    Pure Black GHD
    Pure White GHD
    Benefit ghd
    ghd Mini Styler
    Kiss GHD
    Pink GHD
    Pure Black GHD
    Rare GHD
    cheap ghds
    Ghd
    ghd straighteners
    Benefit ghd
    ghd Mini Styler
    Pink GHD
    Pure Black GHD
    Pure White GHD
    Rare GHD
    cheap ghds
    cheap ghds
    Benefit ghd
    ghd Mini Styler
    Rare GHD
    cheap ghds
    ghd
    Benefit ghd
    ghd Mini Styler
    Pink GHD
    Pure Black GHD
    Pure White GHD
    ghd
    cheap ghds
    ghd Mini Styler
    Kiss GHD
    Pure Black GHD
    cheap ghds
    ghd straighteners
    Benefit ghd
    ghd Mini Styler
    Kiss GHD
    Pink GHD
    cheap ghds
    ghd straighteners
    Benefit ghd
    ghd IV Salon Styler
    Pure Black GHD
    cheap ghds
    Benefit ghd
    ghd IV Salon Styler
    Kiss GHD
    Pure Black GHD
