Join the Car Talk Community!
Discussion Rules
Sign In Register
gas line anti-freeze
With the addition of ethanol now to gasoline is it still necessary to use a gas line anti-freeze such as "Heat"?
«1
Comments
  • edited October 2008
    Not if you have a modern car. In modern fuel systems the gas is highly pressurized all the way through the lines right to the injector orafices. This makes gas line freeze up pretty much a thing of the past.
    Good question! In theory the ethanol should do the job. I never used gas line anti-freeze more than once a year anyway, so it's sort of a moot point for me.
    Maybe a chemist out there will give us a definitive answer.
    Not a chemist, but I did stay at a holiday inn express last night :)
    The gas line antifreeze I have in stock is isopropyl alcohol and that may make a difference. You wouldn't normaly need to add routinely as per Mountainbike, but only when a water issue comes up such as water in the gas you buy or condensation in the tank.
    Tough question. The ethanol is added to make the water, ethanol, and gasoline mix. If the gasahol is relatively free of water, it should take care of water introduced by condensation in the fuel tank. The trouble is that the ethanol makes the fuel more readily absorb water from the air.
    The simple answer is a flat-out "No!" Modern cars using modern gasolines simply don't freeze their fuel lines.
    Occasionally you run into someone who insists it happened to his neighbor's uncle's work buddy. Ask how he knew it was a frozen fuel line rather than some other cold-weather problem.
    Save the Heet or Dri-Gas or related product for known water problems, such as when you go through the car wash with the fuel cap off and the filler door wide open. (I'm not making this up. This forum gets this problem maybe one a month.) Don't waste your money on using it for regular winter treatment.
    The 10% ethanol found in virtually all gasoline is more than enough to scavenge any moisture and prevent fuel line freeze-ups..
    Ethanol does indeed absorb moisture. The problem is that ethanol will phase seperate out of gasoline if gas sits over an extended period of time. You then end up with a top layer of ethanol alcohol, a layer of water below that, and the gasoline making up the bottom layer. Isoprophyl alcohol on the other hand also absorbs moisture, but it doesn't phase seperate out of the gasoline. That's why it's used as a fuel system moisture treatment.
    And contrary to belief, the fuel system on a modern car doesn't remain under constant pressure after the engine is turned off. The pressure slowly bleeds off. But a column of fuel is left in the fuel system so that when the fuel pump restarts, fuel pressure is immediately restored.
    Except on those cases where one has a leaky injector that allows air to enter the lines and displace the fuel as it drains out............
    I can't find the post I made 5 minutes ago on why modern fuel systems make drygas obsolete to amend it, so I'll add to it via a new post.
    In addition to modern systems being a sealed fully-filled line operating under high pressure, multiport systems have the injector right behind the intake port, right behind the valve, a nice toasty-warm area. Carburators, in adddition to having the stuff that you'll see in my invisable post, were located remotely from the heat of the engine.
  • edited September 2010
    Hebei Shineyond Metal Products Co., Ltd ,ltd is located in Asia's biggest screen production base.The company is the collection of development, production, sales for the integration of large companies,it have the most advanced equipment, the loom, technical force is abundant, the process of science, quality testing system is perfect, adopts the high quality raw materialsspecializing ,in the production of gabion,galvanized wire, barbecue net,, wire mesh, crimped wire mesh, welded wire mesh,barbed wire, black iron wire ,stainless steel nets, etc. Products are widely applied in industry, agriculture, construction, transportation, stadium, lawn, breeding, mining and other industries. Sold throughout the country and exported to the USA, Japan, Germany, South Korea and other countries and regions.
    www.metal-china.cn is a treasure of Hebei pu electronic commerce Co., LTD. Invested?Mainly for the steel production enterprise, the dealer, the downstream enterprises and relevant enterprises and institutions to provide steel, steel trading online information online, enterprise, and enterprise Internet solutions, steel marketing management software and warehouse management software development etc. Products cover breadth?besides H-beam, deformed steel bar,steel pipe,channel steel,steel strap, angle steel,steel pipe.It concentrated various network products, mainly are galvanized iron wire, black annealed wire,barbed wire,barbed wire,wire rod,welding electrodeand nails,Because of the professional and updated information, market fast speed, the majority of the members and visitors to the attention and affection. In China's steel nets developmentcourse, total absorption member enterprise nearly 10 million.
    The printing machinery network (www.yja.com.cn), founded in 2001, is now the largest domestic printing machinery industry vertical B2B e-commerce websites. Value-added telecommunication business license Numbers for: hubei B2-20050125. For printing and china printing machine related enterprise products trade and information exchange interaction bridge erection. It has comprehensive application foreground and spread value for label printing machine,flexo printing machine.And it is the biggest online printing machinery display platform. The printing machinery network make full use of the advantages of the Internet, distinctive "Network + publications" , facing the whole country and the world, to provide professional enterprise online, offline various forms of professional trade service.
    With the development of science and technology, home theater has become the general population, dvd box set market more active, DVD and CD look similar, they are the diameter of 120 millimeter, usually used to broadcast TV film, the standard definition of high quality music with great capacity data storage usage.
    Along with painting become time pets, all kinds of high quality oil painting receive a kind welcome in the market. Oil painting reproductions also took the eye of collectors rapidly, even strive with Original painting.
    You can into www.oilpainting109.com to find all sorts of painting, here is the supplier for many world gallery, and online gallery, inevitable - the business of the company is special, can take any image and any size for so many talented artists working, company not only selling cheap paintings, but a high quality supplier too.
    We professional wholesale new era cap,the absolute reputation guarantee and the absolute quality assurance. Various of style. Here, I believe you can find yourself like , you can choose and buy online, we will prompt delivery once you pay.
    We give first-class service, you needn't worry about the quality question, our existing items through professional qc personnel evaluation. Ensure the goods that you receive is complete. What do you still wait, please hurry.
    Optical8 is a store specialised in fasionable glasses and cheap eyeglasses.Take some time in Optical8 and you'll find some ideal glasses in style and fashion. Enjoy your shopping!
    cheap ghds
    Cheap ghd straighteners
    Pure Black GHD
    Pure White GHD
    Benefit ghd
    ghd Mini Styler
    Kiss GHD
    Pink GHD
    Pure Black GHD
    Rare GHD
    cheap ghds
    Ghd
    ghd straighteners
    Benefit ghd
    ghd Mini Styler
    Pink GHD
    Pure Black GHD
    Pure White GHD
    Rare GHD
    cheap ghds
    cheap ghds
    Benefit ghd
    ghd Mini Styler
    Rare GHD
    cheap ghds
    ghd
    Benefit ghd
    ghd Mini Styler
    Pink GHD
    Pure Black GHD
    Pure White GHD
    ghd
    cheap ghds
    ghd Mini Styler
    Kiss GHD
    Pure Black GHD
    cheap ghds
    ghd straighteners
    Benefit ghd
    ghd Mini Styler
    Kiss GHD
    Pink GHD
    cheap ghds
    ghd straighteners
    Benefit ghd
    ghd IV Salon Styler
    Pure Black GHD
    cheap ghds
    Benefit ghd
    ghd IV Salon Styler
    Kiss GHD
    Pure Black GHD
