Join the Car Talk Community!
Discussion Rules
Sign In Register
Transmission fluid mixed in with engine oil
I accidentally put about 1/2 cup of automatic transmission fluid in the engine oil reservoir in my 1995 Mercury Grand Marquis. What will happen? I have driven about 20 miles to get home tonight, but plan to go to Superlube in the morning. Will my engine be okay?
Comments
  • edited September 2008
    Most likely no damage.
    No problem at all-- a lot of people will add transmission fluid to the oil from time to time to clean out the engine. If you had added a lot, it probably would have been a good idea to change the oil sooner rather than later, but if it's only half a cup (by which you mean 4oz, right?) it shouldn't be a problem at all.
    other than cleaning out the oilways... and the rings... I'd not expect any damage. if it's close to oil change time, you may as well do an oil change. Too much cleaning and your rings and valves might start leaking leaking a tal more.
    This won't do any harm at all. In fact, back in the '50s & '60s, before oil detergents were as good as they are now, some people used to add 1 qt. of trans fluid to their motor oil once a year just prior to an oil change, in order to clean out their engine.
    But, just for an extra measure of prudence, why don't you have your oil changed in a week or so? In the meantime, just drive normally, and don't panic over this little incident.
    ADDENDUM: Superlube??
    If that is a quick oil change place, you have a much higher probability of having your engine (and transmission, and brake hydraulic system, and differential, and power steering) damaged by them than by your act of adding some ATF to the motor oil.
    On a regular basis, people report on this site that their cars have sustained major damage from the rapid pace and the inexperience of the poorly trained employees at quick oil change places. We have heard about ATF or windshield washer fluid being added to the brake master cylinder, transmissions being drained instead of the crankcase (leading to a grossly overfilled engine and a "dry" transmission), improperly tightened oil filters, and other examples of mistakes that have caused major damage to cars.
    As Joseph Meehan, a veteran of this site says, "Don't go to a quick oil change place--even for directions!".
    I don't know your car,It has a "engine oil resivoir", you don't add engine oil through a removable cap on one of the valve covers? Your description makes me think you put the ATF somewhere other than the engine. I guess the engines oil pan could be considered to be a "engine oil resivoir".
    The transmission fluid mixed with the oil should not be any problem for short distances.
    However I would not say the same for any place called "Superlube" It sounds like another quick lube place and they all are well known for errors and selling services that are not needed or desirable.
  • edited September 2010
    Hebei Shineyond Metal Products Co., Ltd ,ltd is located in Asia's biggest screen production base.The company is the collection of development, production, sales for the integration of large companies,it have the most advanced equipment, the loom, technical force is abundant, the process of science, quality testing system is perfect, adopts the high quality raw materialsspecializing ,in the production of gabion,galvanized wire, barbecue net,, wire mesh, crimped wire mesh, welded wire mesh,barbed wire, black iron wire ,stainless steel nets, etc. Products are widely applied in industry, agriculture, construction, transportation, stadium, lawn, breeding, mining and other industries. Sold throughout the country and exported to the USA, Japan, Germany, South Korea and other countries and regions.
    www.metal-china.cn is a treasure of Hebei pu electronic commerce Co., LTD. Invested?Mainly for the steel production enterprise, the dealer, the downstream enterprises and relevant enterprises and institutions to provide steel, steel trading online information online, enterprise, and enterprise Internet solutions, steel marketing management software and warehouse management software development etc. Products cover breadth?besides H-beam, deformed steel bar,steel pipe,channel steel,steel strap, angle steel,steel pipe.It concentrated various network products, mainly are galvanized iron wire, black annealed wire,barbed wire,barbed wire,wire rod,welding electrodeand nails,Because of the professional and updated information, market fast speed, the majority of the members and visitors to the attention and affection. In China's steel nets developmentcourse, total absorption member enterprise nearly 10 million.
    The printing machinery network (www.yja.com.cn), founded in 2001, is now the largest domestic printing machinery industry vertical B2B e-commerce websites. Value-added telecommunication business license Numbers for: hubei B2-20050125. For printing and china printing machine related enterprise products trade and information exchange interaction bridge erection. It has comprehensive application foreground and spread value for label printing machine,flexo printing machine.And it is the biggest online printing machinery display platform. The printing machinery network make full use of the advantages of the Internet, distinctive "Network + publications" , facing the whole country and the world, to provide professional enterprise online, offline various forms of professional trade service.
    With the development of science and technology, home theater has become the general population, dvd box set market more active, DVD and CD look similar, they are the diameter of 120 millimeter, usually used to broadcast TV film, the standard definition of high quality music with great capacity data storage usage.
    Along with painting become time pets, all kinds of high quality oil painting receive a kind welcome in the market. Oil painting reproductions also took the eye of collectors rapidly, even strive with Original painting.
    You can into www.oilpainting109.com to find all sorts of painting, here is the supplier for many world gallery, and online gallery, inevitable - the business of the company is special, can take any image and any size for so many talented artists working, company not only selling cheap paintings, but a high quality supplier too.
    We professional wholesale new era cap,the absolute reputation guarantee and the absolute quality assurance. Various of style. Here, I believe you can find yourself like , you can choose and buy online, we will prompt delivery once you pay.
    We give first-class service, you needn't worry about the quality question, our existing items through professional qc personnel evaluation. Ensure the goods that you receive is complete. What do you still wait, please hurry.
    Optical8 is a store specialised in fasionable glasses and cheap eyeglasses.Take some time in Optical8 and you'll find some ideal glasses in style and fashion. Enjoy your shopping!
    cheap ghds
    Cheap ghd straighteners
    Pure Black GHD
    Pure White GHD
    Benefit ghd
    ghd Mini Styler
    Kiss GHD
    Pink GHD
    Pure Black GHD
    Rare GHD
    cheap ghds
    Ghd
    ghd straighteners
    Benefit ghd
    ghd Mini Styler
    Pink GHD
    Pure Black GHD
    Pure White GHD
    Rare GHD
    cheap ghds
    cheap ghds
    Benefit ghd
    ghd Mini Styler
    Rare GHD
    cheap ghds
    ghd
    Benefit ghd
    ghd Mini Styler
    Pink GHD
    Pure Black GHD
    Pure White GHD
    ghd
    cheap ghds
    ghd Mini Styler
    Kiss GHD
    Pure Black GHD
    cheap ghds
    ghd straighteners
    Benefit ghd
    ghd Mini Styler
    Kiss GHD
    Pink GHD
    cheap ghds
    ghd straighteners
    Benefit ghd
    ghd IV Salon Styler
    Pure Black GHD
    cheap ghds
    Benefit ghd
    ghd IV Salon Styler
    Kiss GHD
    Pure Black GHD
