Only risk is avalanches and deer and elk in the middle of the night.
Retuning at 2 a.m. up hill at 45 mph (65 mph zone) a deer trotted onto the roadway.
Thanks to Craig’s List, a donor gave us used rims on which we mounted four aggressive winter tires. The M&S-tired wheels hang on wall hooks.
Chains, shovel, tarp, cat litter, Ensure, toilet paper and spare cell phone. No winch.
You need to understand what “lift kits” do – they raise the frame and/or body higher off the suspension. They do not add any additional height to the axles which limit your ground clearance. They also increase the center of gravity increasing the likelihood of a roll-over. If you feel you need more ground clearance, get a Unimog or a Humvee, not a Hummer (a Chevy Suburban with a fancy body). Unimogs and Humvee have high-mounted axles and reduction gears at each wheel providing amazing ground clearance. If neither of these vehicles work, fire up the snow cat.
Have you considered an all-weather helicopter?? You can bill this service at about $4000/hour…Jacking up your expedition will do NOTHING other than making more prone to roll-overs than it already is…
I-70 and I-25 have not been closed this winter…People drive their Ford Escorts to Vail to go skiing…What’s the problem??? Getting out of the parking lot? Or do you like going over Loveland Pass because it’s FUN!!
Hospitals call us when the weather is too bad for Fright for Life to fly.
I’d love to go over the pass. But cannot justify the fuel use and pollution.
Wife and I did go over in the summer in a Camry. Her firstime. She was scared that there are no guard rails in many places.
Narrow roads, parking, and trying to fit it into your garage each pose unique challenges.
Insurance is higher than most vehicles.
Gas mileage is poor (roughly 12mpg), especially when used as a daily driver.
Maintenance costs are high.
Depending on where you live, it might be difficult to find qualified mechanics.
Noisier road ride than many other SUVs.
Not enough A/C vents inside.
Difficult to pass other vehicles on narrow roads.
Resale value isn’t very high.
Strange as it may sound, the stares and attention can get annoying over time.
Expensive to buy, and even more to keep.
Doesn’t have much pick up & go. Seems lethargic taking off after a complete stop, making it hard to keep up with other cars. Top speed is around 90mph.
Priced too high for most people.
Despite the size of the vehicle, there’s not much cargo space inside.
Towing capacity of 7,000 lbs. is not best in class for an SUV of this size.
Rear visibility is particularly difficult through the small back window.
Front visibility over the tall, boxy hood can be a challenge for drivers under 6 feet tall.
Difficult for shorter drivers to get into the vehicle.
Can only seat 6 passengers comfortably (counting the optional 3rd row “seat” that takes up the cargo space).
What appears to be a roomy interior actually feels somewhat cramped once seated inside.
I think you need to lift your Expedition at least three feet. Then you need to upsize the wheels so it looks like a monster truck. Of course that will mean buying new winter and summer tires.
Nothing makes a 100 MPH Expedition with overinflated tires safer than a lift kit and huge knobby tires!
I am curious. Have you had a problem with huge snow drifts in the past, or are you just wasting everyone’s time for a hypothetical scenario you have never seen?
Dude, you drive an Expedition at triple digit speeds and are/were considering lifting it as well. And you’re trying to justify not going over a mountain because of the fuel use and pollution? Incredible.
In that case, I stick with my recommendation. It will raise the Expedition’s center of gravity and make it more likely to roll over, but what kind of mamby pamby would let a little thing like safety stop him? Be a man! Do it! Jack that sucker up!
After doing as two tone indicated, only then with the increase in tire clearance can you add oversize tires, that’s what increases your axle height. Now you have a whole new set of problems with abs gearing and traction control if you have it.
Thanks. Axle clearance is less than half of the tire height, but I was not concerned so much about axle height as the bottom of the vehicle.
Buth.is too expensive for the few times it may be needed.
Was hoping I could place shims between some components to raise the body and not affect suspension, steering, etc.
If they’re drifts you can manually dig through, then you’d be better off having a small single stage snow thrower stowed in the back or better yet, a Boss V plow on the front to punch through them. Spend $2.5k on a used plow and have it on/off in 10 minutes as necessary.
Per Denver Police Department, name on back of the light bar in 3M reflective lettering and large reflective lettering on clear plastic “signs” inside the back and side windows.
We have the light bar bolted directly to the roof rack so that it can beasily removed and stowed to lessen windrag for long distance returns.
Ordinary white Expedition except for a red LED Stop/turn/tail lamp mounted on the inside wall of each front wheelwell not easily noticed in the dark well just above the tire.
